3/8" Steel for Hunting ?
8.1K views 19 replies 11 participants last post by  Maniac
Here is my compiled Slingshot Ammo Size by Type of Game. I use 10mm for hunting rabbits and ducks.
Ammo SizeSteel Ammo CharacteristicsLead Ammo CharacteristicsRangeGame
5/16-inch (8mm)This size is too small and lightweight to be effective for most huntingHeavier than steel of the same size but is also more appropriate for target shooting10 – 20-ydsPractice mostly, but some small birds, rodents, or reptiles.
3/8-inch (9-9.5mm)Fast but not heavy enough. Only suitable for close shooting in the head and neck.Does not do enough damage passing through, requiring high accuracy.15 – 25-ydsSquirrels, rabbits
25/64-inch (10mm)Most often used for target practice but okay for mid-range huntingHeavier than the steel, this shot is ideal across a wider range of distances and game types10ft to 50-ydsSquirrels, pheasant, turkey, pigeons, rabbits
7/16-inch (11mm)This steel shot has the same qualities as 25/64 lead and is a good alternativeToo heavy and not recommended for long-range. Devastating at close range.Steel: 10ft to 50-yds Lead: 10 – 20-ydsSquirrels, pheasant, turkey, pigeons, rabbits
15/32 (12mm)Heavy and low rangeBurdensome for hunting and not recommendedOnly very close range up to 10-ydsNot recommended
10mm steel is a very underrated ammo. I think it has the perfect balance between heavy and light., 8mm steel is considered light, 9.5mm is medium and 11mm heavy. However 10mm steel is right inbetween the medium and heavy range, so it doesn't feel too light but at the same time its heavy enough to do serious damage and good distances when hunting. And you don't need as super heavy bands with high draw weights as you do with 11mm steel. Just my opinion :)
