1 - 20 of 31 Posts
Love me some slingshots.
interesting concept,love the glow in the dark :)
Thank you! These are a bit on the smaller side but they are awesome! And the glow stuff is a bit hard to blend into the wood but I'm sure I can get it close enough to where a few good coats of clear gloss should make it a smooth transition 馃 if not still cool and comfortable.
still trying to figure out the blue "fork" tips,,,resin?
So with stabilized wood they take a piece of wood and soak it in a solvent epoxy mixture then stabilize it which sucks that epoxy deep into the wood the solvent then goes away and your left with a very solid slab of expoxy and wood.
Discussion Starter · #19 ·
Hybrid resin 馃憣馃幆馃憤. My cousin does some unbelievable tables doors guitars you name it with this like but alot of the wood if stabilized it's with cactus juice I'm sure? Unless it's going on the pressure pot which forces the resin into the wood. 馃憤馃幆馃憡
Yes you are correct. He does both types as well!
1 - 20 of 31 Posts
