I was strolling through an office supply store a while back, and I will give you one guess as to what I always look at when I go to such a place. If you guessed rubber bands, you get 10 points! Just on spec, I picked up a package of Alliance File Bands, in rather garish colors.
These bands appear to be the same width and thickness as #32s, but they are 7 inches long. Hmmm, I wondered how they would perform on a slingshot. Well, I thought they might be just the ticket on one of my Altoid Tin shooters. Here is the rig I settled on.
From my previously reported experiments with #32 bands, I decided to chain one rubber band to the pouch and then braid one more to the first band. The bands were attached to the wee frame with bolt on Gypsy tabs. I used a tiny little pouch just to see what sort of speed I could get. I HATE that little pouch, and would never use one that small for any other purpose than trying for speed. The bands were long enough that I could draw full butterfly, which for me is somewhere between 60 and 65 inches, depending on how I hold the pouch.
Well, bottom line ... How did they do???
That little sucker hurled 1/4 inch steel at a consistent 270 fps. And perhaps surprisingly, it shot 3/8 inch steel at 225 fps. That was over the Chrony in my dining room at a chilly 66 degrees F. The amazing thing is that the draw weight was only 5-6 pounds.
If you would like to see some more amazing results, check out my entry in the Slingshot Forum 300 Club.
Cheers ..... Charles
