Looks like you are off to a great start!
That's a frame you can cut out with a hacksaw, too.
Is that 1/2 inch?you might have better luck drilling holes around the design,and using a coping saw-wood blades-.wear a respirator when drilling and sanding,or any machine work,and i use bees wax to *grease* the saw blades,burts bees chapstick is fairly cheap and works, i learned all these from on here,so figure i pass em along.Good looking PFS,solid shooter!I got started on this last nite. Couldnt find good jig saw blades, or my "heirloom" hacksaw, so got a new on for 6 bucks,, well worth it. I only got this far. I just used the last of my Rem oil for the cutting lube, wasnt bad, but I figured Id stop before I got worn out , the wknd. is coming! The other pic is one I got from Andrey Bloblank,, from Ukraine. Do any of you have a idea how he gets this "aged" look. Sure would be cool to do that on this PFS , if it wasnt too many hard to obtain chemicals needed.
I want to thank you guys who gave me advice on the cutting.
Good Morning, thank you! its just 1/4 but its a full quarter, I did a bit more w/ the mini hacksaw as recommended. I had one just needed new blades. I dont have a drill press, so drilling around is a bit laborious. But Im down to just some file work , and then the surfacing. Ive done enough to see any metals are prob not going to be my thing. Ive bent 1/4 oak into a hoop and that was easy compared to cutting thisIs that 1/2 inch?you might have better luck drilling holes around the design,and using a coping saw-wood blades-.wear a respirator when drilling and sanding,or any machine work,and i use bees wax to *grease* the saw blades,burts bees chapstick is fairly cheap and works, i learned all these from on here,so figure i pass em along.Good looking PFS,solid shooter!I got started on this last nite. Couldnt find good jig saw blades, or my "heirloom" hacksaw, so got a new on for 6 bucks,, well worth it. I only got this far. I just used the last of my Rem oil for the cutting lube, wasnt bad, but I figured Id stop before I got worn out , the wknd. is coming! The other pic is one I got from Andrey Bloblank,, from Ukraine. Do any of you have a idea how he gets this "aged" look. Sure would be cool to do that on this PFS , if it wasnt too many hard to obtain chemicals needed.
