Update: After I posted this I asked my wife to watch the video with me and try again. If there are any ladies with small nimble fingers out there reading this, I might be single soon. Any interest in a guy that's too dumb to slingshot?
Wrap and tuckWrap and tuck is plainly simple and effective.
There are many resources to get slingshots, with/without clips, other than where you are looking. I am willing to bet $1000.00 that Pocket Predator will help you with your issues. They are fine people and stand behind their products.Thank you all for your help. I emailed pocketpredator about my issue and they recommended the rubber band method. I was really hoping for a slingshot that would be very easy for me or my son to maintain in the field. Since the smart ties don't work and the forks are wobbly I asked them if they have a return policy. I don't know if they accept returns and I honestly wouldn't blame them if they don't give me a refund considering that there seems to be no quality guarantee on their web site. It's my own fault. As a novice I shouldn't have ordered without some sort of guarantee. If they are gracious enough to allow me to return this product, I'm considering purchasing something from simpleshot.com. What do you guys think of the Ocularis banding system or the Quick Clips from simpleshot? Are either of these actually easy? If pocketpredator doesn't do refunds, I'll probably try the wrap and tuck method on a forked stick to get started (since the forks are wobbly on the SERE).
This proves that I'm dumb. I can't wrap my head around this. I don't understand how accuracy wouldn't be affected from the forks moving. It seems to me that there would be a lack of consistency between shots if the forks moved around with each shot. If the angle of the forks relative to the handle can change by a few degrees, I would think that shot placement would be inconsistent. I'm obviously too dumb for this hobby.I have a SERE. And I have made a couple breakdown slingshots myself. A little movement in the fork is common in a two part assembly. There is no worry with that as far as accuracy or safety in the SERE. It is a solid shooter. You can eliminate the movement with a bit of paper inserted at the joint if you like. I find I rarely take mine apart, anyhow.
When I talk about movement, I mean the tiniest discernible shift, sometimes sensed mostly as a click.This proves that I'm dumb. I can't wrap my head around this. I don't understand how accuracy wouldn't be affected from the forks moving. It seems to me that there would be a lack of consistency between shots if the forks moved around with each shot. If the angle of the forks relative to the handle can change by a few degrees, I would think that shot placement would be inconsistent. I'm obviously too dumb for this hobby.I have a SERE. And I have made a couple breakdown slingshots myself. A little movement in the fork is common in a two part assembly. There is no worry with that as far as accuracy or safety in the SERE. It is a solid shooter. You can eliminate the movement with a bit of paper inserted at the joint if you like. I find I rarely take mine apart, anyhow.
