1 - 9 of 9 Posts
Here is a start to my modification of a flipkung using PLASTI DIP.
PLASTI DIP now sells a color kit that you can mix any color you want. I only used cans of premixed colors yellow and red.
If you want to do this I figure that making a tray just the right size and configuration from a few sheets of tin foil is the easiest way to make a tray that accommodates the size and shape of the SS so as to not waste material.
It isn't complete. What I will do since this is an experiment and I want the corners round I will slice off the material on the corners so that the successive coats will continue to help round the handle. I don't know how it will slice but I am confident it will work because I straightened out the edge where the metal shows using a razor blade. Imagination is what you can make it.
Hint about mixing existing colors; They don't easily (or at all) give the color you would think that mixing two primary colors might give. Therefore the color kit may be a good idea if you want a specific color value.
Oh yeah, this is dipped twice. I expect to dip it two more times and have what I want.
Cool! I hope the successive coats will come out the same color, it's very nice.
I expect that the final coat will be better because the first two were the learning curve part.
Perhaps a mod will move this to modification thread. Whoops on my part.
"Mighty Can Smiter"
That's pretty neat looking, Ray.
I also fullfilled your request ;)
LGD
HOBBYIST-SOPHOMORIC-JACKA$$
like dipping a candle. when i cut off the clean lines, i use a razor or an exacto knife and just slit and peel/shave off what i dont want.
SSF Founder
Have you tried the Spray on Plasti-dip ray? It would take more coats, but might give you more artistic freedom, and maybe a more consistent finish?
It probably wouldn't give you more artistic freedom in terms of mixing colors, like if I wanted periwinkle or bright pink :)
However, you could certainly do some fun stuff with a camo look in earth tones.
Too bad the kit doesn't come in neon colors. I would really get crazy with this.
1 - 9 of 9 Posts
