No one can use an offset smoker? Didn't get a single recommendation. smokers for restaurants
I am also looking for the suggestionI'm new to "the brethren " and smoking. Any recommendations for a beginner's first smoker. I'd like to start out doing ribs, commercial smokers brisket tri-tip, chicken.
Thanks, maty
Nothing against this place.....but check out a BBQ forum.I am also looking for the suggestion
I am really fall in love with this BBQ setupNothing against this place.....but check out a BBQ forum.
That said, I own a Webber Kettle, Vision Kamado and. Custom horizontal.
The Kamado is the most versatile.
The Webber isn't a great long smoke vessel, but fine for ribs or chicken.
The horizontal is the most fun, most traditional and gives the best food. Also hardest to learn.
swimming pool cartoons
I don't care for the simplicity and lack of technique needed for pellet or propane smokers, so I won't give any more opinion or judgement on them.
View attachment 361679 View attachment 361680 View attachment 361681 View attachment 361682 View attachment 361683 View attachment 361684 View attachment 361685 View attachment 361686
tired of my cheap Brinkmann smoker-doesn't hold heat in cool-cold weather. thinking of the weber 22.5 smokey mountain cooker. how is this smoker and does it do ok in cool-cold temps? is there some better smoker available? probably less than $800. thanks.If you saw one of my posts, I have a PBC or pit barrel cooker. Pretty simple and can cook quite a bit if need be. Check out their website.
If you want to spend more time managing the fire, maybe the Weber Smokey Mountain series. Not too expensive, and they have books that can walk you thru chapter by chapter with different cooks and rubs. I would only recommend...buy quality first, even if you need to go a bit smaller. I definitely would not go with one of those Home depot things with a thousand parts and sharp edges. And I also would not spend $700 for some type of "green egg".
I had a buddy(Filipino believe it or not) who spent some time in texas. When he moved back to San Diego(my hometown), he had this giant BBQ the size of a small car, it was built on a trailer itself and pulled around with a trailer hitch. He used to have these big parties, and cook a whole pig or cow for 200 people dream garage. I think he still has it in the backyard...that thing was amazing.
Any ceramic smoker will do much better in cold temps than the WSM.tired of my cheap Brinkmann smoker-doesn't hold heat in cool-cold weather. thinking of the weber 22.5 smokey mountain cooker. how is this smoker and does it do ok in cool-cold temps? is there some better smoker available? probably less than $800. thanks.
Yep, it's not the best, but it's not the worst. I've done anything from sear steaks at high heat, to low and slow ribs/pork shoulders/etc. The snake method with coals and indirect heat you can do just about everything, just takes a bit more effort for longer cooks.It's "The Way".
