1 - 15 of 15 Posts
heres wot i believe to be my best yet.i think the hardest thing to do wen making a catty is make your design i believe ive not seen one like this its based on a starship made with a mild steel frame and a pine carved ergo handle and wrist brace the handles got sum unknown wood capping the bottom stained with antique pine .ive been thinking about making a few of these to sell them wotcha think ?
cheers grant.
. Air gun Trigger Wood Musical instrument accessory Shotgun
Musical instrument String instrument String instrument accessory Musical instrument accessory Guitar accessory
· Brotherhood Of The Slingshot Nutz
I don't like the way the handle is attached with just screws. I think it would fail over time. How about welding a 3/8" rod to the frame, drilling a 3/8" hole into the handle and epoxy the handle to the steel rod? I totally dig the rest of the slingshot though! Great work man!
Yea I know wot u mean my original idea was to weld some threded bar and drill the a hole all way through the handle and bolt it on the bottom but I need a longer drill bit the wrist brace could do with a bit of work too
Don't get me wrong, I like your design a lot. I think it is great. I share my ideas too because if they are crap, hopefully someone will say it. That top portion of your slingshot looks bullet proof compared to two screws holding on the handle. I would hate to be shooting it and have the handle come loose. That metal wouldn't taste very good mixed with my blood. I hope you continue with the idea, because it is a good one to pursue and I just may be a future customer.
· Quis custodiet ipsos custodes?
I think that design is excellent, although personally I would have extended the forks a little bit more, I'd love to see what it does with a fully extended butterfly!
Thanks guys for the advice I've made slingshots in the past for my own use and if they wer to fail then it would b my own fault but if I'm making them for someone else the saftey would be my no 1 priority
grant
I like that. If they were 2" bolts, I'm sure they'd probably be fine. Seeing as the rest is welded, there's no big reason not to use an all steel core. Even if the rod only goes in half way, it'd be strong. I look forward to buying one soon.
Discussion Starter · #14 ·
Yea I've drilled the holes 6.5 mm Which will be perfect for tapping out 8mm then apoxiing two bolts in . How much do u guys reckon I could charge for them ? Many thanks for all the advice
grant
1 - 15 of 15 Posts
