1 - 18 of 18 Posts
My first try at slicing a big fork for frames - my bowsaw handled the cross-cutting OK but is struggling with the ripsawing - any advice on blade type, please, like where to get a dedicated RIP blade in UK?
Meanwhile I am keeping the wood wet to prevent it from getting harder, does that make sense?
Mike
Pull saw with large teeth and one with fine teeth.
The thing with pull saws is lighten up on the draw/pull because it requires less force.. just let the tool do the work.
I like this one and it is on Amazon...
https://www.acehardware.com/departments/tools/hand-tools/hand-saws/2075372?x429=true&utm_source=google&utm_medium=cpc&gclid=Cj0KCQiAh9njBRCYARIsALJhQkFeZfKILCCVo6SAgaKOeSxFaJlfch-8o-uAGPVq6h5ocgR6ulD1uUEaAkUaEALw_wcB
Also for roughing out wet limbs see this or similar item...
Meccion Professional 8" Folding Hand Saw Heavy Duty 7TPI Tri Edge Mn Steel Blade - Ideal For Gardening Pruning, Tree Trimming, Camping and Hunting (8) https://www.amazon.com/dp/B07BF7RG3K/ref=cm_sw_r_cp_apa_i_dhYDCbDEF1N4Q
I'll take that advice and give it another go.. cheers buddy
Here, take one of this saw, and your problems are solved for long time, and in future you just need the replacement blade when its got dull: https://www.fine-tools.com/ryoba.html
WOW! Thanks, lovely website, very reasonable prices.
I have Jap pullsaws for carpentry and small-boat-building, with seasoned wood, but this is very green damp wood, and I am ripping not cross-cutting. I shall email them with my photo and ask their advice.
Many thanks, very helpful!!!
Mike
Thanks, very helpful. I love pullsaws, I have had 2 of the exact same Shark Saw and now have the Irwin clone same size. They are great for general DIY in dry wood but a bit too fine for ripcutting thick green wood, in my experience.
I have a Draper folder pullsaw for my pocket when foraging, cheap but good enough .
Mike
Discussion Starter · #14 ·
If you can afford it, you cant go wrong with a Silky saw. I use one every day .
Thanks, very helpful. I have googled Silky Saw and it is a pocket folder pullsaw? Yes, I have a Draper fplder pullsaw for foraging, but please look at the size of this mega-fork, and remember, I am ripping not cross-cutting.
Mike
Hi again.
I emailed Dieter Schmid at Feine Werkzeuge and he replied as follows:
"Thank you very much for your interest in our range of tools and your inquiry. Unfortunately, for rip cutting we can´t offer you something faster. Today it´s unusual to work this way."
So I'll have to persevere with my bow-saw and maybe my Stanley Jet Cut.
Or give it all up and watch TV instead. :)
Thanks,
Mike
Discussion Starter · #17 ·
Looks like you're using a 21" Bowsaw Forester, try fitting it with a Bacho 23-21 blade. Although not what you're looking for, it will make a big difference to the efficiency of your Bowsaw.
It's the Bahco23-21 21" Hardpoint Bowsaw Blade I think, I've found it for a reasonable price. I'll probably order it later today, I'll just compare it with the blade I am using first.
Just buying a new blade like mine would probably help as well. Ripsawing brings out the worst in a half-worn blade.
Many thanks, very helpful.
Mike
Discussion Starter · #18 ·
I have now remembered that my existing blade is a Bahco that I bought from our local hardware store some years ago, though it has not had a lot of use.
So today I went to the same hardware store and the only bowsaw blade that they have is the Bahco 23-21 21" for £6.99, and it looks exactly the same as my existing blade. So I have now bought a new one and am looking forward to trying it.
Thanks again,
Mike
1 - 18 of 18 Posts
