Butterfly with PFS
1304 Views 13 Replies 9 Participants Last post by  skarrd
Does anyone shoot butterfly with a pickle fork? Or am I the only one?
Reactions: 5
1 - 14 of 14 Posts
I do! And it's a blast.
I didn't start out at full butterfly, I started at half butterfly and worked my way up to full.
Sent from my MAX_10 using Tapatalk
Reactions: 4
I have some, and think there are several to many who do.
Reactions: 3
Right on! Glad to hear I'm not alone haha. What size ammo do you shoot?
Reactions: 2
Welcome to the forum!!
Everything should be shot full butter. lol 😂
I shoot 7/16” steel or .44 lead
Reactions: 5
I've been shooting 7/16" steel balls with no problems at all.
Reactions: 2
Bout all I have is PFS shoot 3/8 in , 1/2 in. clay and 3/8 steel
Sent from my LE2117 using Tapatalk
Reactions: 1
I do! EVERYTHING should be shot butter! I mostly shoot 3/8 or 7/16 steel, but with Pfs I usually shoot marbles or clay. Just because for me a Pfs is purely for can bashing fun.
Reactions: 3
I didn't know there was any other way to shoot PFS?:p
Reactions: 3
ocassionally,with 5/16s and 3/8s steels,lately i have gone the other way learning short draw [cheek anchor] having shot long draw [behind ear lobe] my whole life this is a newer experiance and definately faster on the reloads using mostly 1/2 in and 5/8 in marbles
Reactions: 1
"Long short draw"- I hadn't heard it put this way before, but I like it! And I have been pondering this over the past week. So apologies for the long post with a lot of "thinking out loud", but you shook the tree I have been climbing all week.
While playing with fork width and all recently I have been comparing my cheek anchor to my under the ear lobe anchor. As the "long short draw" aptly captures, my under the earlobe anchor is a good inch and a half longer than my in front of the ear lined up with my cheek bone. And just this morning I had the chrony out and figured out that this makes a 2-3% difference. Not much, but something. And real and reproducible.
The other difference is that the in front of the ear or on the cheek bone is higher and closer to the line of sight, which means less hold under / over at reasonable ranges, but faster drop off at longer ranges. All relative to line of sight- the actual trajectory doesn't really change. The lower behind the earlobe anchor has does have a bit more hold under / over at closer ranges, but relative to line of sight stays above the target longer (launched at a steeper up angle relative to line of sight).
So I dove into a black powder round ball ballistics program that was put up here (I can't remember who posted it) and have been driving myself crazy trying to decide if I want to shoot a wider fork from behind my ear lobe or a narrower one from a higher anchor / with a shorter draw.
In the end I decided to make identical frames and try both ways, with the fork width adjusted to have the frame dead on for vertical at ~15 yards for each anchor. If the playing around with the ballistics program is right, even 3/8" ammo going at 240 fps (entirely reasonable) should be maximum 2" over or under at any range between 5 and 20 yards. And 5/16" stays within 1.5" over or under anywhere from 5-20 yds when going 265 fps.
Now to see about matching reality to theory. Personally I'm rooting for the "long short draw" as I like this anchor and although the difference is small, it does produce a bit more power.
And once I get it all figured out to my satisfaction, I will probably scrap it all and go full butterfuly full time.
Reactions: 3
Thanks everyone glad to be here! I like 7/16 the best for how I shoot. Before I went to butterfly I was getting real accurate with the old-school upright hold anchored right under my left eye. The draw was short but with the right band set up I could get some good power as well.
Reactions: 2
yes i have been using really short tubes for the under eye/cheeck anchor-4in AL in 2040,and get sufficient power and accuracy to severely damage the next moccasin that i see,however i just found out that at that particular junction of the San Jac river there are alligators,sheesh,back to packin the pistol for river walks,,,,,,,,,
Reactions: 2
1 - 14 of 14 Posts
