A long time ago, about 20 years, I cast my own pistol bullets in 3 calibers. I still had the pot and a lot of lead in the basement so, decided to order a mold and dipper and went on line to see what Lee had. I got a .45 cal two cavity mold with handles and a dipper for around $35 shipped Fed Ex to my door. Hunted up some beeswax to lube the mold and flux the lead and after a quick skim to clean out the slag I was ready to pour. I pre heated a corner of the mold in the lead and cast my first two balls. The mold, suprisingly, was at temp quickly and I started to get perfect round balls after 4 fills. Seems the aluminum heats up faster than the old steel mold blocks. So, I am off and running with my own home made heavy balls for hunting.
One suprize was that the .45 cal I cast weighed 110 grains and muzzle loader balls in .44 cal weighed 117 grains???
Then I remembered, the old lead that was in the pot was a hard mix for pistol bullets to prevent leading the bore and was a mix of lead, tin and antimony, (I forget the precentages) and the Muzzle loader balls were pure lead, so actualy heavier, though slightly smaller in diameter.
I forgot how relaxing it was and how much fun and satisifaction I had years ago making my own. Give it a try, you won't regret it.
