1 - 20 of 20 Posts
Sorry if this exists but I've searched and nothing came up.
How deep should a catch box be for target practice? I have a nice solid plastic box I could use but by the time I've hung 2 sets of material they won't be much depth left.
New to the hobby and moving from clay to bb as I keep going through the clays too quickly and feel like I'm on a constant reordering cycle.
Thanks. Got the box cleared but cannot post a picture due to being a noob (I think).
Depth is 20cm. It's a good size to throw in the car hence why I want to use it.
So thinner material as first stop? Thinking folded T shirt for first and something heavy for second?
My box is 12" wide x 13" tall x15". The target is 4" from front. No bounce outs unless I use a hard target. I use mostly leather spinners and paracord with knots tied in it.
I also kept it small to be able to transport.
Mostly everything already covered, so I'll just add that make sure the curtains can't be pushed back by the ammo and hit the back of the box.
I stupidly put my wire framed folding catchbox against a wall once at 10m and shot myself in the face on rebound. Good job my reflexes are fast or could have been nasty
Neophyte
One trick that has helped me a lot is to use a pillow case hung so it moves freely in the box to stop the ammo. This may be counter intuitive but it works. I did not come up with this idea and can not remember who did. The light material slows down the ammo gently and deposits it in the bottom of your catch box. Mine is about 8 inches or 20.5 cm from the back of the box. I have found that the pillow case must hang free barely missing the bottom of the box for the best results I trim the length from the open end. I have a rod ran through the tip top of my box and feed it through the case and clip it in place on the ends with large binder clips. Just my 0.02 :)
aka CYBORG
Fiveshooter discovered the pillow case idea after much experimenting ... works beautifully. You're right, it has to hang freely but close to the floor of the catch box. He uses the $5/pair cases sold at Walmart.
Discussion Starter · #16 ·
Box up and running.
Got 2 bits of paracord strung across the width at the top with a folded T shirt on the back one and 2 layers of muslin type dish cloth on the front.clothes are perfect size.
Getting maybe one in 5 bounce out from a short distance so should do they job when I take it some where with more range.
Box up and running.
If you got out in the woods much like I do then what I do is I have a decorators dust sheet I place between branches or bushes and have spinners on paracord. It is a safe backstop and will save your shots to use again.
Sent from my crystal ball
Discussion Starter · #18 ·
Box up and running.
Cheers mate. Think I'll invest in some sheets for when I go waking. Wouldn't want to carry box with me for that anyway.
I use a terry cloth draped over a piece of welding rod, held in place by clips, cut short of the floor. In front of that, I use a t-shirt on a rod ran through the arm holes, held in place by clips , cut to length, no bounce outs with 7/16 ammo though I haven't been shooting them at max. speed.
1 - 20 of 20 Posts
