I've read and responded a few times recently about chained rubber bands and bending steel frames, so while at the hardware store I walked by the steel rods. I said "what the heck" and picked up a 1/4" piece and bought some #33 rubber bands, latex of course. Went into the shop and bent the frame with a propane torch and a soft faced vice. I like to use heat because I can but the bends more easily right where I want them. You don't have to use heat. I made the ears as basic as I thought would work well, so others might want to try this great little slingshot that will shoot any kind of rubber you want to use. The only critical part is the gap for the bands to be able to slip through. I just use a feeler gauge set for .050" and squeeze the rod down until the tip traps the gauge. Pull the gauge out and you have a nice gap for your rubber. No marks were caused by tools in making the rod, so I could go right to polishing the tips for the rubber. I used black jewelers rouge on a cotton wheel until it was slick smooth. Then just start at the pouch with the first link and continue until you get the length you think you want. If you make it too long it is easy to take out a link with this frame in the field. I had fun making it and now I am going to go outside and relax shooting it. You can easily convert this type of frame to shoot indoors at a catch box also for when the weather turns bad. We used to make stuff like this out of coat hangers when we were kids. You just twist three wires together, very tightly, using a vise and a pair of vice grip pliers. Here is the picture, I don't have the T-shirt yet.
