I will try to be as concise as possible - apologies for the long winded theoretical question...
Lets say we have a bandset that shoots 6mm steel at 250fps, and also shoots 8mm steel at 200fps. I think this is reasonable...
The faster traveling, lighter ball will loose less height at least at shorter ranges - but, because it's lighter and traveling faster, it looses more of its speed as it travels.
The question is, at how long a range is the drop of the heavier 8mm ball (that is initially traveling slower) equal to the drop of the lighter 6mm ball?
Alternatively, is there a simple trajectory-plotting software for spherical objects?
I'm trying to figure out if this distance has practical application in ammo choice - given a bandset of desirable draw weight.
Thank you!
Thank you!
