1 - 17 of 17 Posts
Hello,
I have attached rollers to the compass slingshot design.
But this time, I went all the way - I attached rollers at the top AND the bottom of the frame, adding more than 30 cm (12") of rubber! This is so much that you have to pull out a bit in order to move the pouch over the top of the forks... but the result is worth the efforts, a ton of power in a small frame.
I even made the bottom rollers detachable, so if you need a compact slingshot, then you can simply shoot it without the draw length increase.
I used tiny ball bearings (inside dia 8mm, outside dia 12mm) for the pulleys, those are from RC cars... They work really well.
I am pleased with the way it came out!
And here is the video:
Greetings
Yeah, you should be proud of that slingshot!!! ZERO DEAD RUBBER! The baddest slingshot ever! I wonder how much more that tree can take! Ha!
Hello
Great slingshot! Are you able to shoot it sideways like the chinese people shoot theirs? In your video I could not understand what you said about the band size , is it not as wide as the hunterbands ?
Did you measure it with a chrono yet? Are you plenning to ?
Thanks ;Jaydee
Smaller isn't really possible, this is already as small as can be. The rollers need to run parallel to each other, that is the problem.
I can shoot it sideways, just fine.
The band issue: My band is 50% longer than the band Fish uses (20cm vs. 30cm). Hence, if I would cut the rubber with the same width as Fish does (2x3 cm fork, 2x2 cm pouch), then I would have to pull a lot more rubber (50% more), which would lead to 50% more draw weight. A bit on the tough side, even for me, especially as I wanted to pull this out to the limit.
I wanted the same draw weight as the Hunter, which I think is a great setup. So I had to cut the rubber more narrow in order to pull the same amount of rubber.
But of course this slingshot is more effective at the same draw weight, simply because the acceleration phase is much longer.
The slingshot gains between 15 and 20% in speed over conventional frames with the same draw weight. Max values aren't yet possible, it is still too cold.
Regards
I saw the video Bud=AWESOME!. A real effective use of rollers in a compact design. NICE! Flatband
All Joerg's slingshots are beasts.. He said in the safety post he got eye damage from a band snap.. I'd dare say for the rest of us, a band snap from a Joerg sling would be decapitating.
Nicely done Joerg.
1 - 17 of 17 Posts
