I was inspired by Biker Bob's post about his new Falcon that he got from China. I have made several slingshot rifles out of many different materials and have always had difficulty with consistency, I think part of that reason was I never had sliding rails. I would pull the bands back to almost 600% with my hands and then slide them into the release trigger. It always felt treacherous and scary every time, I had a couple of times where it didn't seat properly and I got smacked in the thumb with 11 mm steel and that was really not very pleasant. The bigger problem was consistency, and I could never quite get that figured out.
I went ahead and ordered a sliding rail kit from Amazon with 10mm hardened steel rods and picked up a trigger and slingshot head to mount to the front. After a day of building and another day of fiddling and getting it just right, I think I've got it figured out. The hardest part was the locking mechanism to hold Carriage that holds the laser and firing trigger in firing position. After a lot of thinking I found a very simple method, a steel bar and some very small grooves in the steel rod with some rubber bands, and later latex tubes to lock it in place. Works perfectly and it is very secure never had one problem with 100 shots so far.
The rail kit I received from Amazon is top notch. The sliders have metal bearings inside so that the steel rod moves effortlessly. Sliders are also pre-tapped for M8 screws so I can get a very tight connection. Very good quality here, and I've ordered a second rail kit with 48" (1240mm) rods to go with my Falcon that'll be here in the next month from China.
I used single looped 3050 tubes and in this setup I can move 8 mm Steel fast but not crazy fast. I have my stretch at 600% so I was a little surprised that it doesn't move the ammo faster. I have a 33 inch draw on the rifle and I tried using double looped 3050 tubes and did not get the same consistency but it moved 3/8" steel like a bullet! I will continue to work on those and try and get everything even and see if I can't get it more consistency using the double looped tubes too.
Taking lots of advice from everyone here I got some dry graphite spray, adjusting the pouch every time to be perfectly even and using only clean ammo and am getting good results. By the end of the day yesterday I was able to hit a 50 mm spinner every time from 10 meters!
All of my shooting was done right around 32°F, it definitely made my technique more important with those cold temperatures. I found that if I counted to 6 as soon as the carriage was locked into place I would take that shot as I said six and I could get good consistency. If I wasn't exactly on the money with my timing the shots would be high or low. I can only assume this would not be such an issue in normal temperatures but I'm glad I was able to figure it out for the cold temps. I am using a high quality green laser for sighting.
I hope everyone has an awesome week!!
Vince
Vince
