1 - 20 of 22 Posts
Whatever your style of shootng is, have you measured your draw lenght ? Mine is 58 inches.
What is the length of the rubber that you pull to 58"?
Have you used a chrony?
I have not invested in a chrony yet. I use the Tex Express Bands one for each side and they only come 10 1/2 inches in length but they surly stretch. Tex tapers them from 3/4 inch to 1/2 inch so by the time they are secured they are actually 9 inches .
Like this:
I am comparing the Tex Express Bands to Theraband Green.
Tex makes a beautiful band set.
At what draw length will you chrony the Tex Express Bands? I only use one per side. I am curious at what draw lenghth would be the most advantageous in Feet Per Second . My shooting draw pic .
58"!?! I couldn't draw to 58" unless I held the fork between my feet.
I normally draw maybe 28"; longer into the butterfly but I don't do that regularly and would fall well short of 58".
You should see the Chinese slingshots. I bet danny'll opine, but he's around my height and probably draws a couple of feet.
I am not a tall individual and im more on the compact side. My point is to get all the slammin, jammin speed I can out of my shooter when I need to. The beauty of my Glove shooter is that there are no fork, finger or hand hits if your off a little and no hand slaps so I have no hesitation about realy pulling back .
My draw length from the fork tip to my ear is 31 inches or 79cm the tube length is 4&3/4 inches or 12cm.
79/12 = 6.58X What band, pounds, and how long do they last?That is way, way, over 250%
I'm not scientific it's 1745* dankung tubing, pounds = ? no idea last a very long time,I have to change one tube every now and again I use four strand fixed tubing on the Bi - Thor dankung. The same method is used on my handmade also.
Discussion Starter · #20 ·
I think I like the Hand Made Shooter over the Bi-Thor. Very Nice work on the MDF.
1 - 20 of 22 Posts
