Easy travel slingshot rifle design
2772 Views 14 Replies 7 Participants Last post by  JoergS
Take this Slingshot-on-a-stick design, and instead of cutting rectangular holes, make them round to fit a broomstick.
Take the fork and trigger with you, and find/buy/borrow a broomstick at your destination.
1 - 15 of 15 Posts
Well it is different not sure if I would trust it's safety though.
What is your safety concern?
Stu, I like this path you're on. It can be followed by anybody, because it doesn't take a lot of expensive tools to make. I, for one, don't want to have to acquire a cabinetmaker's shop just to make my slingshots. Good job, and keep it coming. I enjoy your videos.
Thanks,
You 'get it' and you understand exactly what path I am on.
Believe me, If I can make it, anyone can make it.
Some folks love to make beautiful wood items.
They will buy expensive tools to make great looking fountain pens out or rare woods.
To each their own.
I am thinking of the next step.
Would you like to see a video of me stepping on the front fork and drawing the trigger back?
Incidentally, drawing with the fork on grass is safe in case of an accidental release.
Concrete could be very dangerous.
I am thinking of a hinged safety flap at the fork (sponge or carpet) to absorb the shot and prevent ricochets.
As for the trigger/safety would you like a passive release of the front of the clothes pin, or a squeeze release at the rear?
Stu, I have a couple of concerns for safety. But the main one is the pouch release mechanism looks like if it's not seated just right it will flip out unexpectedly.
The sliding pouch release holder is a good idea, and the way you're doing it is KISS... but a little on the dangerous side right now.
By putting the pouch release mechanism through a hole, instead of an open top design... you can pretty much eliminate that problem.
Also, I still don't see why you need both the slingshot AND the release mechanism holder to slide along the stick. By simply attaching a short piece of square OR circular tubing to the end of a regular stick you have a combination thumb hole/ slingshot retaining hole for your hiking type stick. Doing it that way you can use a lot of different slingshots instead of just the one.
Heck the easiest thing to do, is to get a piece of 1" PVC pipe and a "T". Cut the pipe to the length you'd like your hiking stick. Cut one end off the "T".... sand and smooth it for a comfortable feel... And you're all set for a LOT of different slingshots. If it isn't just perfect for a particular shooter you'd like to use... you can use a lighter to soften the "T" holding end and it's easy to form.
I like the idea of a slingshot that can be improvised locally with only a few brought parts.
I'd like to see any videos you think can help, Stu. Thanks. I'm paying attention.
Bill,
Great feedback. Solid ideas. Thanks, man.
Well how does the slingshot on the end stay put what secures it,in the video you just seem to wiggle it a little until it stays put for a second.I just had visions of it flying back and hitting you I was watching with one eye open and the other one closed.
I love your videos and love how simple it is to make. I like inexpensive ideas like yours and think your project is a fun one to make. A slingshot rifle out of stuff you can find around the house and make for no cost. Slingshots have been used for hunting to get food when times where hard thats what makes this hobby so great you don't need lots of money to buy a slingshot you can just make one for free.
If you look carefully at this video you will see the (really not needed) safety notch at the end.
Once you wiggle it into the notch it cannot come back with the rubber tension pulling it.
There is more wiggle at the notch end than on any other place along the stick.
This is safe. The notch is more for superstition than for safety, it is NOT needed. I tried to MAKE the frame shoot back (in safe conditions), it is not possible, not even with oil. The friction is so strong that the fork locks in place even with less than a pound of draw. The higher the draw, the safer it gets.
The only thing you have to avoid is to get your hand into the line of fire while cocking. It may happen, even though that is not likely, that the shot breaks due to a mechanical failure, and then it would be painful.
Fine I was not being funny it just looked iffy on video and im no professional, I have only been using slingshots since october last year so my knowledge is not as great as many on this forum just reacting to what I see.So from what i understand from Joerg friction is holding it in place.
Yes, friction it is. Of course in addition to the friction, there is the notch at the end, obsolete but psychologically soothing.
1 - 15 of 15 Posts
