Eye dominance is a subject a lot of people have not heard about and others have heard the term but know nothing about it. Every person has one dominant eye. If you are right handed then it is assumed you are right eye dominant. The dominant eye controls our coordination and if we are RH and RD (right hand right eye dominant) then all is well. But almost one in three is XD (cross dominant). I came to these figures by years of teaching shooting both in pistols and long bows. Before you can shoot to the best of your abilities you need to draw under the dominant eye. The closer you draw to the eye the more this rule applies. In other words if you anchor on your cheek bone and opposed to under the chin. An anchor point is a place on your body that the drawing hand touches just before you release the pouch. In my case my thumb joint hits a spot under my cheek bone.
How does one determine which eye is dominant? Glad you asked. The best way I can give is to have you get a piece of paper 8 /12 X 11 inches is fine. Cut a 1/2 inch hole in the center. Hold the paper by its edges and well below your waist, have your elbows locked straight. Look at an object on the wall sever feet away from you. Now slowly raise the paper up until you can see the object through the hole in the paper. Do not bend the elbows. When you can see the object through the hole do not move one thing and hold as steady as you can then if you are right handed close your right eye. If you do not still see the object then close the left eye and the object should be seen. If you are left handed reverse these instructions. Now if you closed your right eye and you can see the object with the left eye open then you are XD. Chances are you have been shooting right handed and wondering why you are not hitting the target. Well now you know.
In every case where I have had a student with this problem I have switched them to shooting LH. All at once they started hitting the target. My advice is to switch and get it over with. Sure you can fight it and some days you will really shoot good then as soon as you get tired or stressed the dominant eye takes over and your shooting goes in the dump. Now if you are drawing to your mid chest and shoot instinctive you may get away with not switching. But I still recommend you switch. If you do not switch then a lot of the problems you have will still be there when you are not shooting. I will address those problem in a very short paragraph just so that you know.
Some XD people go through life with baggage. This does not apply to all but those who read this will know who they are. When you are XD the two halves of your brain are at war and sometimes short circuit. XD people will want to go through a doorway and turn right and at the last moment will turn left and walk into the door jamb. They will want to put the directional signal on to turn left and will turn right or flip the signal lever in the wrong direction. I don't know how many people who tried to go around a coffee table and end up kicking it with their chin. They will see a sign that shows on left or right turn, the one with the bent arrow and a circle around it, and will have to stare at it for a while and figure it out. What makes matters worse is they start beating them selves up thinking there is something wrong with them. Once they are told what the problem is they can relax and things improve. Another thing XD people can do really good is read upside down and backwards. This blows people away. I am XD and if I have a hard time understanding a drawing or instructions I will turn them upside down and all at once it is clear.
I will do another article on instinctive shooting and more of this will be covered. if you have any questions please ask.
