good one eh!That's pretty durn fast, Darrell. Not many predators move that fast, let alone prey species. I think the Mantis Shrimp is about the fastest out there strike wise.
But I've seen a stonefish eat a mantis shrimp and that happened so fast I thought I was mistaken. He was there and then he wasn't. All I saw was the "rock" twitch slightly.
Keep going 'til you have to change your name to dblurr.
Thanks for pointing this out and now I will have to make a change on the title. .20 the two numbers do occupy the hundredths place but are actually 2 tenths. If I understand this correctly. If this is so I should have already known this.i think you set the bar so high no one else is even giving fast draw a try. well done
(it's two tenths not two hundreds- but if it was possible you'd be the man to do it)
you are right.Ok, so after reading this how to read a stop watch then the .20 should be read as 20 hundredths of a second
