How to guide
Firstly you will need 2 foot of elastic 2 pins a pair of catapult forks a pouch and some strong fishing line.​
Double the line over and put it through the hole then put the elastic through the line and pull it back through the hole under tension until it forms a rubber loop.​
When the loop is in place push the metal locking pin into the loop and pull the elastic tight.​
Cut off the excess elastic.​
Finally push the elastic through the hole in your pouch then double it over and tie it off under tension. For a great finish cut off all the tag ends.​
ALL INFO FROM http://www.bellsofhythe.com
Or you could go through all the trouble I did and bring it back to original cube band attachments style with wooden collets. Flatband
A short while back I bought some square laccy with bands attached and wooden colletts inc. Fit a treat too. Have a look at ebay item no 260616388913 and see for yourself!
Personally I found them a little long but easy to trim. Better too long than too short I suppose, prob supplied this way so people can cut to length.
Cheers,
Chuff.
