Tks, wonder if these pouch dies are able to be sharpened when they get dull, and if so, how ?
You're welcome P. I worked in the corrugated industry (in design) & have a lot of experience in these die cutting rules. The secret in keeping them sharp is just 'kissing' the softer platen when punching through. I dont know what is supplied with these or the methods being used to punch them... fly press & flat nylon plate? (hdpe) What method are you using?Thankyou Trap1, I appreciate that info. They are razor sharp. I think I will get many uses before they go blunt.
I made another sheet of GZK pouch material with both sides laminated this time. Contact adhesive definitely adds alot of strength.
Good selection of styles there & agree GZK have good stuff.. I'm going to check out his tips.Trap1,
There is a type of plastic, a lot like a thick cutting board used in the kitchen. The plastic gets hit with a claw hammer at the moment as I don't want to buy a Arbor Press.
BIGDH2000 Slingshots & Catapults
GZK Pouch Die - Tips & Tricks
That is what I have found, but I ordered from GZK because he has a good reputation and I needed a band tying jig.
Cheers PK.
