1 - 12 of 12 Posts
Hi all,
I have a friend who is a hunter but who never hunted with a slingshot. Now he wants me to make him a slingshot and he says it would be used almost exclusively to hunt pheasants.
What setup should I make for him (I have only TBG) and what ammo should I recommend/make for him (I can cast lead balls)?
(If that matters at all, I have a nice, not-so-small natural fork for him and he will use it hammer grip).
Thanks in advance!
jazz
For 9.5 steel and 8mm lead hunting with tbg I'd use a 30-25mm taper and for 10mm lead balls double 25-20mm taper, should give enough power to fill the pot for your mate ;)
Sent from my SM-G960F using Tapatalk
Thanks, Ukprelude, this sounds completely ok!
cheers,
jazz
What is his draw length?
73 cm (corner of the mouth)
cheers,
jazz
If he can't guarantee head shots, then I don't think that anything can beat 1/2" or 0.40 lead. A body shot with one of these monsters should be enough to harvest a pheasant. I know, I know, I always recommend 1/2" or 0.44 lead for hunting, but I do consider it the safest choice.
It does need some heavy bands to propel it fast though, so I would probably go for 0.44 lead. I haven't used TBG in a long time, so I am not sure what would work, but I would try a more "conservative" single band setup, 30/20 taper, and test it at 10-15m and adjust band power accordingly.
Hi skropi, this is also an interesting approach, thank you!
cheers,
jazz
What would be your opinion on 11mm (7/16)?
Sent from my SM-G960U using Tapatalk
7/16 lead I assume? Well, it is probably overkill. The 1/2" definitely is. That's why Matt suggests 8-10mm :) I guess it depends, but a skilled shooter shouldn't have any issues with 8-10mm lead, as I am not skilled and I successfully hunt with 9.5mm steel which is less forgiving! Mind you, I only hunt birds with head shots though.
Sorry I meant 7/16 steel it's bigger than 3/8 (9.5) but a little smaller than 1/2" steel
7/16 steel is nice and heavy, exactly my preference for hunting! Please do note that even though I prefer heavy ammo for hunting, I hunt almost exclusively with my target setup, shooting 9.5mm steel. That is because I take game opportunistically, and it mainly happens when I am target shooting.
You will never need more than 10mm steel in the UK. I believe a lot of guys there are actually moving down to 8mm which does make some sense.
The fact is the largest game would probably be rabbit or pheasant - shot placement (head shots) is the most important followed by an adequate setup.
Its always a trade off
Light / fast / flatter shooting / light draw / potentially more accurate / could be affected by wind / less kinetic energy / more shots per pocket / less expensive
Heavy / slow / more drop / heavy draw / potentially less accurate / less affected by wind / more kinetic energy / less shots per pocket / more expensive
Personally is a money thing - I use ammo thats consistent, affordable and capable. In the Uk seemed 9.5mm steel was that.
1 - 12 of 12 Posts
