1 - 8 of 8 Posts
Hi guys,
I don´t know if I have a problem or not. I´d apreciate your advise.
I´ve got some great tapered kits made of theraband gold.
However, my slingshot is not made of wood (which I could tie over the tip); it´s metallic, with two polished screws (8 mm diameter), where I have to tie the therabands.
Should I fold up the part that will be hold to the screw? And the main question: Will it affect to the accuracy? And if I do it, won´t it waste the power of the wide part of the theraband?
Thanks in advance,
Max.
How about a picture? I'm not sure if I'm understanding what you're saying
What Pallan said...
FYI folding the tube does not reduce the power and accuracy shouldn't be affected as long as both sides are the same.
1 - 8 of 8 Posts
