How many wraps? I was using a scrap .9. No slippage of the bands. The wrap material did not stay in place.Without modifying the frame, do as AKA Forgotten mentioned. Lay down a wrap (or 2 if you are using amber belt) to give some rubber grip to the fork tip. Since that frame is HDPE, you might need to use a latex strip instead of the amber belt to keep it from slipping. And yes, still wrap a turn of latex strip, then lay the band on that and keep wrapping.
Just as tight as I can. Sometimes I need 3 handsSammy, I would ask how “tight” your wraps are ?
I do as Robert ( Raventree78 ) does, by laying 2-3 turns down on the bare frame first, laying the band on and lay down 2-3 more then flip up the tag ends of the band and continue wrapping until there is just enough left to tuck it.
I also pull my wraps to the max stretch I can get wrapping very tight to the frame….haven’t had any slippage yet, even on my HDPE frames.
Great idea Reed, kinda like checkering a rifles buttstockIf the wrapping isn't stopping it, then use a dremel in the groove with a cutting wheel and just lightly score few waves into the groove on the side that you attach the band too. Once the slippery hdpe is roughed up, there's no more chance for slip.
I use amber belt, stretched out completely tight under the band. 3 or 4 wraps completely covering the groove is enough. I have one frame that I had to modify or rough up the groove. You can see the scoring in the open groove but the wrap and tuck completely cover it when banded.
