1 - 12 of 12 Posts
Not sure if this should go here or in “homemade slingshots” - I’ve been tossing around too many ideas and probably complicating the matter so was thinking about a thread showing different homemade Slingbows or DIY slingshot to Slingbow modifications. Hoping to see the awesome work of the forum members and maybe get some ideas too!
I have read this whole sub-forum; there are some great examples spread throughout.
This is one of the reasons I wanted to master making my own band/tube sets tailored for sling bows; to make it easier to create/mod.
I have several projects in the works; I'll post as things come together.
Hoping to see other's ideas and examples too.
Read all the good and bad reviews about these:
Motor vehicle Automotive tire Bumper Automotive exterior Automotive wheel system
Not real impressed right out the box crappy clam shell packaging; but, I got them on clearance for hardly nothing (plus they are the deluxe package with an included arrow).
Got some ideas for them...
About 10 years back, I went through a sling bow craze. I built many and bought a few, but the one I always settled on and shot the best for me was just a simple OPFS. You can shoot balls or arrows without changing a single thing. Replace your arrow knock with golf tees and your golden. Great for hunting. See a squirrel, use a steel ball, see a bunny, use an arrow..........or just a steel ball lol.
My final one I made i made the handle portion a little larger and put a palm swell similar the a recurve bow, so it made it almost a hammer grip. Then made the forks just a touch wider so the band tied wouldn't interfere with the arrow. But no deeper, the original depth of the V is perfect to rest the arrow in.
I just liked this one for me because you could go from shooting arrows to balls/rocks with zero modifying your setup. Sure if your shooting 300 grain arrows you will be over powered with 3/8 steel. But I liked that you don't have to fiddle with a whisker biscuit, or remove some gimmicky rest. Definitely not for everyone. But that's just what worked for me. Hope this helps, or sparks and idea!
Interesting to see what you do with those. I bought one on a whim once. A total bust! The arrow's insert was damaged and I was not able to screw the included field point, or any other field point into it. The bands broke within a few shots, the metal bolt holding the arrow rest is flimsy and the bolt hole for the bolt is poorly drilled. I could not get the arrow to stay in the rest and eventually built a kind of whisker biscuit using feather scraps. Never could get it to shoot. Went back to my bows.
Blue Raja, I had read your post regarding your experience with the Pocket Hunter. :imslow:
It gave me some reservation about buying, but I got them dirt cheap (I bought 3).
I didn't have the problems with the arrows, but what you say about the bands and arrow rest ring true.
I found the arrow rest loose and rattles and the screw indeed sucks. I'm planning on using some silicone glue to dampen the rattle and try to find a better bolt to replace the screw.
The tubes seem to draw short for me and I don't really trust the plastic inserts holding the pouch on this model.
I also couldn't get the arrow to easily nock onto the string/pouch. I'm going to get some of those Pocket Predator clamps and use bands instead of tubes.
1 - 12 of 12 Posts
