How many shots should I roughly be getting with the obvious fact that it will vary between band sets. I'm currently only getting about 400ish shots out of my bands and am disappointed with this. I am using single TBG 25-20mm tapers. I know theraband is pretty bad and I am ordering some GZK but I still want to get the most out of the rest of the theraband that I have. Shooting 10mm clay balls which are a bit light for the taper which could be a factor. I cut all my bands at 17cm with the pouch tie and fork ties in mind so about 15.5cm of active band length. So how many shots y'all getting out of a set?
Wasting way too much energy for long band life. Also make sure that your fork tips have no square corners.
It would seem that you can't have it all in one set of bands. Shooting clay is making the bands snap back kind of like a stock whip.
On the other hand 3/8 steel will give you kill power. I would suggest two sets of bands. Maybe one or the other rolled up in a pill bottle.
Don't take that much to change over when needed. Just my 2cents worth.
PS: 400ish shots ain't that bad.
Alright cheers bud.
Lately I've been cutting my Precise 0.65 bands 3 gen. at 15 cm. So, the actual lenght considering attachments is about 13 cm., anchor point in the mouth.
Yes: very short life bands but also very powerful and extremely accurate.
