1 - 15 of 15 Posts
I am a beginner and I was wondering how to aim. I know you could use the middle of the 2 forks but how do you aim to get maximum results? I know this may be a useless question but I was just wondering.
Thank you very much. So you use the tip of the upper fork to aim.
Yes.
You just line the bands up, one on top the other, so they appear as one when seeing them under your eye. Hold to your anchor point. Use the corner of your top fork as an aiming reference.
If the shot goes left or right... you're not lined up under your eye correctly. You must line those bands up under your eye, and use your imagination to make that line extend all the way through the target and beyond.
If the shot shot goes to high or to low... adjust up or down to compensate... really quite simple once you've done it enough.
Also, if you keep both eyes open instead of closing one the fork will become transparent
allowing you to align with your target easier.
This simple advice changed everything for my accuracy levels. They went from 50 percent
to a consistent 70-80 percent nearly overnight.
Try it you'll like it!
I use the middle of the fork (the center of the two points that bands tie )to aim .
The person on the picture is NO.1 slingshoter in china
Can you link us to any videos?
http://www.tudou.com/programs/view/IaDDr5OcqCc/
http://v.ku6.com/show/H0Q-JskAGp5iAeOr.html
http://v.youku.com/v_show/id_XNzQ3MTM3MjQ=.html
When Mr. Dengfeihu (chinese name:邓飞虎)was young, with the help of his accurate slingshot, He help a girl to get rid of some bad gays.A few years later, the girl marry Mr. Deng.
I hope you will enjoy the videos above.
He is certainly a good shooter... but number 1 in all of China?
Most of, if not all the shots I saw him perform in the videos, I can do... and let me tell you something, I'm not nearly as good of a shot (with rifle or bow) as quite a few guys I know and know of. If they ever decided to use a slingshot I'm sure they'd be better than me with that as well... the USA doesn't have nearly as many people as China and of that number a far less of a percentage actively use slingshots as well compared to China...
So what I'm saying is, it just doesn't seem right that guy could be the number 1 shooter in China... unless those videos aren't really representative of his true skill level.
1 - 15 of 15 Posts
