Hey guys,
Well after completing a little natural I thought I would complete a tutorial on attaching tabs (how I do it anyway).
Equipment/What you need:
1) Get your slingshot/catapult ready.
2) Depending on the width of your naturals forks mark out, in my case 2cm (20mm) was the right size, on to your leather. The length should be approximately 9cm (90mm). Using a ruler and a knife, cut along the marked line. Repeat the process, one for each fork tip.
3) Lay the leather on top/underneath the natural, and mark off a suitable length with a pen or pencil, as shown in the picture. Leave enough space (gap in the leather) for your tubes to fit through.
4) Now you need to cut a strip of leather to wrap around the tabs, this adds strength and hides any fishing line or string that may be used to secure tab. This strip should be approximately 1cm (10mm) thick and long enough to fit around your fork tip. Repeat process, so you now have 2 strips.
5) If all is going correctly up until this point, you should now have something that looks like this.
6) Now we need to begin glueing. Apply a decent amount of contact adhesive to the leather tab ends and the fork tips of your natural. Let this dry (this is how contact adhesive works). Join the leather tab and fork tip, aligning with the mark you previously made. Repeat for both fork tips. Fishing line can be tied on around the tab for extra strength and support.
7) Next you need to do the same process, applying adhesive to both strips of leather and the tab on the fork, let dry, and join.
Here is the adhesive I am using, It is very strong and has worked extremely well in the past:
8) Now your natural fork should look like this
The finished product:
- Natural slingshot/catapult
- Leather of your choice
- Knife
- Contact adhesive
- Vice (optional)
- Ruler
- Pen
