How do you successfully install each rod of Hi-Vis material into the sight picture accessory? Not sure of the technique used for best success and durability?
Any ideas would be greatly appreciated.
from what i was told from the seller, you cut the piece to fit in the hole, with a lighter, singe 1st one side, then the other, to make stay. .
WOW. Pure genius!
I was headed into the area of brute strength and squeezing it in with a pair of small needle nosed pliers. Wondering if a heat gun would provide the same result? Thinking about my abilities with a lighter and the possible resultant pile of burned/singed pile of plastic I'd have left, at least until I refined my techniques? Conan the agrarian strikes again! Snagging the wife's high speed hair dryer might be less risky, maybe? And just in case, plan B? Where would I access more hi-vis material, given my current level of experience in dealing with things almost out of focus for my bifocals?
Appreciate the patience and support in advance.
