well you could see what the thicknesses are, thera gold is 0.8mm thick i believe, from that you could work out the cross section and the overall 3d mass of the object, ofcourse this wouldnt be exact and any kind of taper would i believe involve triganometry (sp?) to work out...
the other way is to just rough guess...
or an easy way that may work and seems right but may not be, look at the thickness again, if one band is 0.5mm thick and someone is using a 0.8mm thick then:
(1/height of your band)*height of thera gold = x
(1/0.5)*0.8=1.6 therefore multiply the widths of the band at pouch and fork ends by 1.6
this isnt an exact science since square rubber with the same cross sectional area as thera gold bands would perform differently i dont believe.
but its probably a helpful start and ive simplified it a fair bit =)
Paul
