Post 1, branch selected from a local doctor's office. I called and got their OK, before cutting.
Identified as a Morella, or Bayberry shrub.
Jake, I think the only Boss that Sammy has to listen to, is the one he is married to. :bowdown:Working on frames at work? Shame on ye !
I won't snitch on you if you don't snitch on me! :naughty:
Looking good Sammy. Some natural forks look good with a little bit of bark left on too. Don't worry too much about a perfect clean up, it will add character.Last 2 days efforts. This Elm is HARD! 80 grit is taking the larger side down, little at a time.
I use a four in one rasp. Even it is much better than sand paper for removing material quickly.Thank You, I ordered a rasp, but the teeth on cut on the push, 4 tools on 1 bar. I ordered the Shinto
. You won't be disappointed in the Shinto, I promise.....if you don't like it, I'll gladly trade you a custom natty for it .Thank You, I ordered a rasp, but the teeth on cut on the push, 4 tools on 1 bar. I ordered the Shinto
