1 - 20 of 31 Posts
Hello,
have made my first Kydex test pouch today.
I tied the ends with string to allow the pouch to open.
The Kydex is way too thick (2,5mm) and I have to optimize the form, plus I will add a funnel for easier loading. But it works!
The scattering is just the way I like it. The target in the picture is one shot, from 5 Meters distance. No "tissue bag", I just plainly loaded the lead balls (4.5mm) into the pouch, one side for now because of the lack of a funnel.
Next weekend, I will make a much nicer one and present it on video!
Regards
It is too early to say if the shot makes any sense. When I finished the testpouch, it was already almost dark outside. Penetration tests will have to wait, same thing for the slomo video studies.
But I can also shoot the 19mm lead/steel balls out of this pouch. One thing is for sure: The grip on this pouch is phenomenal. You can pull harder and release cleaner than using a leather pouch. There is potential in the idea, as Saunders already prooved with their plastic pouch.
I have to find thinner Kydex, this pouch is too heavy (8 gramms). 1 mm Kydex would be ideal, then the weight would go down to about 3 gramms, same as a leather pouch.
I will keep working on the concept.
I'm watching the development of this one with lots of interest ! I have wondered about cutting a wide spot, in the middle, on one continuous band to flip shot.
Interesting It appears that the projectile's pattern is a thick line, like a duckbill shotgun has.
How many projectiles are used for one shot?
I'd think that would be a variable # depending on shot size. If you were to use a #12 shot(or 1.2mm), as the .22 rimfire shotshell uses, you'd have quite a "Skeeter Eater" . Also the pattern will likely be more densely populated once Joerg works out the filling funnel and fills that pouch to capacity. Should be very interesting to see the results.
Isn't it great to find a material that is just what your looking for? I'm nterested in the video of this.
Jorg, are you getting PM notifications? Sent you a PM. The site says you haven't read it. So I wondered if you are aware they are there.
Stay creative.
Discussion Starter · #14 ·
Got the 1mm Kydex today and made a pouch.
This works fantastic! I designed the pouch in a way that it can not fully open, just enough to let the 19mm lead ball out. This leads to very tight groups when I use lead shot! Even from 10 meters, several balls hit the air rifle target (which is small). At 5 meters, all of them are in the air rifle target.
I smashed an apple from 5 meters! No tissue bags whatsoever.
But it also shoots very good with lead balls.
The only issue: You either have to wear a glove or shoot it flipstyle. The pouch is not heavier than leather, but much harder, so a handslap might cause cuts, would hurt very much for sure.
I mould kydex and work leather. I recommend a leather pouch; the leather can be wetformed and skived in the middle at the hinge to make it flexible. It won't crack or chip and will be a little gentler on your fork hand.
I put together a multi-shot pouch just to show another way to do it with leather. The pouch has a stitch taken on both sides to form a pocket. It can be shot by just pouring the shot into the pocket or you can pre-make several shot shells in advance as shown here. I make then by separating a two ply tissue and using just one ply of it. I line a thimble with it and pour it full of shot, then tie it off with thread and trim. This way you can carry several and reload quickly. The 2nd picture shows a pattern at approximately 5 meters. Multi-shot shooting does not have much killing power as the small shot just does not travel fast enough. -- Tex
Nice Tex!!! I've done that before as well. I believe that it was on the old Whammo instructions as a "DIY" project. It is interesting. I really like the idea ....I wish it had more killing power, but you are correct in saying it doesn't have much. I do think it would take doves and such at close range, but I haven't actually tried yet, have you Tex?
It will not take any thing larger than a sparrow effectively. I use it with sand to kill red wasp around the house, as they get very aggressive. -- Tex
1 - 20 of 31 Posts
