I saw this design by The Gopher
http://slingshotforum.com/topic/5196-small-aluminum-plate-shooter/
and wanted it! However, until my arm gets better, metalworking is out of the question. Setup and clamping, plus turning the wheels on my homebrew milling setup are just too awkward with one hand.
However..... I CAN do a little bit of woodworking, if I keep it simple.
So this is where my fancy took me:
The wrist lanyard is absolutely mandatory, or this little guy will closely follow the bullet downrange.
Two improvements I will make: Shorter band set, and wider/deeper grooves to retain the band set.
Now if only my arm would heal up, I can put this thing to work!
