Now that I've abandoned short draws for good, I am slowly discovering that step by step, I am heading towards full butterfly. 3/4 butta feels....a bit cramped already, so I need to cut my bands longer and longer. The Chinese ruler cutters obviously don't work, as they don't allow for 35cm band lengths, so what do you all use? Normal plastic rulers? Are they durable enough? Or maybe something else?
I was thinking about finding some acrylic stuff or something, but I am not sure how to go about it.
One way would be to create your own templates using acrylic or mounting board or foam plastic sheets? Something that it rigid but you can cut easily? Then you just align rulers to the template and cut as usual with a rotary cutter. Long steel rulers would be handy!
I use a piece of aluminum angle from the hardware store. I think it's about a 1/16" (2mm) thick by 3/4" (19mm) wide in both directions and 3' (92cm) long. I manually measure and mark the taper at either end of the band before cutting, probably one reason why I've come to prefer straight cuts.
Dang Bob, I was just going to post the same thing. turn the angle iron down so it forms a teepee (A) . The aluminum will make a perfact straight edge, and the soft metal won't damage you cutter if you are careful.
