Now the 3/8 steel should be fine. I believe it weighs as much as the 1/2" clays. So you should be tight on track.
I hope so, I recently was watching a YouTube video. And heard that there are some ppl hunting with the clays. I couldn't believe that there are ppl who are but they aren't bad. They definitely might get the job done if you have nothing else.The steel should be even better. It has higher density, hence higher ballistic coefficient. It certainly has more consistent spherical shape than clay balls. We will see. With good recapturing arrangements steel may even be as affordable as clay.
-TL
Honestly not terrible, wish there was a bulk order of 1000.The best I could find is 500 3/8" steel balls for $12.45 off Amazon prime.
-TL
You got the link?I see the Amazon has 1000 Qty 3/8" Inch Steel Shot Slingshot Ammo Balls for $19.95
You will find it by searching for 3/8" steel balls 1000.You got the link?I see the Amazon has 1000 Qty 3/8" Inch Steel Shot Slingshot Ammo Balls for $19.95
I use the catch box and recover about 90 percent. But the ones that cream the target shatter, as well as the ones that bounce on side of catch box. 1000 clays will last me 3 months. The shatters will kill the longevity.Or 3000 steel balls for $53. I don't want to buy that many, because I plan to recapture most of them. 500 steel balls should last as long as 3000 clay balls.
If I can recover 80%, I will still have more than 100 balls left after going through the balls 6 times or 3000 shots, so it can be more economical than shooting disposable clay balls.
-TL
https://www.amazon.com/Inch-Steel-Shot-Slingshot-Balls/dp/B07TBJ34LW
Already in my cart. Thanks a plentyYou got the link?I see the Amazon has 1000 Qty 3/8" Inch Steel Shot Slingshot Ammo Balls for $19.95
I built this a couple of months ago. Takes a beating and keeps on eating. I would do something stronger than card board some of those shots you will be pumping into it will be moving fast. After constant hits will more than likely break through.I plan to rig up a cardboard box trap with hanging t-shirt as backing. The paper target backed by cardboard or soft skin metal can will be hung in front of the fabric backing. Probably not much steel balls will shatter hitting those. I will see. Probably 500 balls will last me long enough.
-TL
Well, if you're out camping, shoot marshmallows...Hello. Just got back into slingshots after I retired. Have a few different set ups, catchbox etc., but found I prefer to plink stuff around the yard and in field while camping over always shooting into the box. I have found that this burns through ammo rather quickly. Am I missing something or is this the cost of my new hobby. Asking for a friend...
Curious as to how much the clay weighs, and it's diameter. Also, are they consistent in all shooting respects?Kinda the cost to play. At least steel will eventually rust and return to nature. A good alternative to steel for use in the yard and out and about is to use clay ammo. Readily available from eBay and Amazon. I pay about $20 for 4000! Works out to basically shooting for free!
Clays weigh less than steel if you are comparing same diameter to weight. So in order to get a better feel you have to get bigger diameter clay to kinda equal out. The 1/2 inch clay should get you where you want to be weight wise.Curious as to how much the clay weighs, and it's diameter. Also, are they consistent in all shooting respects?Kinda the cost to play. At least steel will eventually rust and return to nature. A good alternative to steel for use in the yard and out and about is to use clay ammo. Readily available from eBay and Amazon. I pay about $20 for 4000! Works out to basically shooting for free!
Thanks,
THWACK!
Are the clay balls consistent in size and weight ?Clays weigh less than steel if you are comparing same diameter to weight. So in order to get a better feel you have to get bigger diameter clay to kinda equal out. The 1/2 inch clay should get you where you want to be weight wise.Curious as to how much the clay weighs, and it's diameter. Also, are they consistent in all shooting respects?Kinda the cost to play. At least steel will eventually rust and return to nature. A good alternative to steel for use in the yard and out and about is to use clay ammo. Readily available from eBay and Amazon. I pay about $20 for 4000! Works out to basically shooting for free!
Thanks,
THWACK!
I would say not 100% consistent. Sometimes you may get the some off smaller one. They do try to get you the same size and weight though. I have not had many problems with the clays that are 1/2" in size. The 3/8 ones were too inaccurate for me to keep shooting. And were just too darn small.Are the clay balls consistent in size and weight ?Clays weigh less than steel if you are comparing same diameter to weight. So in order to get a better feel you have to get bigger diameter clay to kinda equal out. The 1/2 inch clay should get you where you want to be weight wise.Curious as to how much the clay weighs, and it's diameter. Also, are they consistent in all shooting respects?Kinda the cost to play. At least steel will eventually rust and return to nature. A good alternative to steel for use in the yard and out and about is to use clay ammo. Readily available from eBay and Amazon. I pay about $20 for 4000! Works out to basically shooting for free!
Thanks,
THWACK!
Many thanks!
THWACK!
