1 - 18 of 18 Posts
The fork is white walnut and I wanted to keep it as white as possible.
However, after testing a brushing polyurethane varnish, a brushing water-based varnish and a wood oil, on a piece of spare pine, I decided to go with the wood oil and forget about whiteness.
Largely because I know about varnishes already, but using wood oil, I would learn something new.
I used Rustin's Danish Oil and followed the instructions on the tin. One coat with 20% white spirit added, then two full coats.
For each coat I flooded the oil on liberally with my favourite Handover 2107 Series half-inch brush, waited about 3 minutes, then wiped the surplus off with small folded pieces of kitchen paper tissue. I damped the paper with oil first, so that I was wiping off only the excess, not pulling the oil up out of the wood.
The 5 photos show the result after 3 coats.
They also show my sanding imperfections. I have learnt to try not to use the coarse, 60 and 80 grit papers cross-grain, as it is a lot of work to sand out the scratches with the finer grades.
But I was not looking for perfection - my original 1955 catapult was much rougher than this, and was without surface finish.
I like this oil - it is a "hard drying oil", so after a day or so, it is very dry and hard with no trace of stickiness.
I'll post again showing the assembled catapult and its build details in a few days.
Regards,
Mike
Oh sweet hominy! That is awesome... nigh perfect in the level of "inperfections"... that is quality personality.
Beautiful fork and you did a great job on the finish.
Reactions: MakoPat
Discussion Starter · #18 ·
I am now looking for a second fork so that I can play with this Rustin's Danish Oil again . . . :)
Mike
1 - 18 of 18 Posts
