1 - 8 of 8 Posts
Ah, the eternal hunt for power...
I still have these 130 g 30mm steel balls. If I can shoot them at 60 m/s, that would be 270 Joules, almost 200 ft/lbs, more than a .380 ACP round (9mm kurz). That's the goal.
Of course that can't be done with a conventional slingshot.
So I am planning to do make a special crossbow with a permanently attached winch. The winch will pull the entire trigger/lock part to the cocked position. The trigger/lock assembly will slide inside of a rail frame, so the cable can be attached straight with no "sled canting".
I will experiment with the rubber to max out the power.
Will be a brutal weapon!
would it not be better to use lead instead of steel ammo, there will be less air resistance for the weight enabling a easier/more powerful set up?
sounds like a great idea, will you use a 'saw tooth' style crank to keep it held in place?
looking forward to seeing this produced, you always do a great job
1 - 8 of 8 Posts
