1 - 16 of 16 Posts
Hi everyone! First post to forum.
Im sorry, but i dont own any real slingshots, never even tried any. But in my childhood i allways build lazy projectile shooters from Lego bricks
Now in later days with engineering backround i made crossbow style brickshooter once again.
Im really proud for my achievement. Never ever imagined you can build something this powerful from plastic Lego bricks.
Here is facts about the gun:
- Crossbow style, include barrel roof, Not open rail.
- Pulleys at front, no crossbow limbs.
- 2040 Dankung tube power source. (1745 tube in order)
- Pump action, pulls ammo from clip. (15 ammos in magazine)
- approved projectile: 1x2 techic lego brick 0.82 grams https://www.bricklink.com/v2/catalog/catalogitem.page?P=3700#T=S&O={%22iconly%22:0}
- ~40 m/sec, 131fps
- Also shoot everything that fits in the barrell.
What is best way to improve projectile speed and accuracy even more?
Should i extend barrel = more draw length?
Maybe some other type of rubber? Only tubes area compatible.
What role front pulley diameter does?
I know it is not as powerful than real slingshots. But compared to my childhood, this is not a toy anymore. With sharp ammo it penetrates soda cans in 10 meters.
With blunt 1x2 bricks it shoots throught cardboard.
Have to try steel ammo sometimes.
I will post some pictures later.
Welcome! Sounds very cool, love to see some pictures of that never thought of using Legos but I know they can be strong especially if you were to glue them together. Thanks for sharing
cheers
I allways try not to modify any of the bricks. Glue is cheating. I have to make structure strong enough that it can support the load.
I took some measures: Tubes rest lenght are 5.5-6" and draw lenght is only 16". Should i cut tubes a bit or extend barrel? What stretch ratio should i aim for? There is extra slim brick under the main 1x2 ammo brick that i forgot to sum. True ammo weight is 1.18 grams which is about same as 1/4 steel.
I would say in general you can do a stretch of 500% on 2040 tubes. I would suggest not going that far but maybe 400% since my experience with slingshot rifles is that if you extend the stretch to the max you get less accurate shooting.
· Super Moderator
Welcome, and WOW, what a neat build!
For increasing power there is a good answer. I recently built a (very rough) slingshot rifle to test the factors affecting power. Not nearly as cool as your build but it was compounded with pulleys and used 2040 tubing (the results should apply to all latex).
The bottom line is draw length is king. So a longer barrel will help. Next is getting the elastic to stretch to its optimal length. Depending on the latex in your tubes that will be 500-600%, or having the draw length being 5-6 times the length of the relaxed band. This ends up being sort of a bummer since it limits how far the latex can come back along the bottom of the frame- if it came as far back as the hold on the top your elongation factor would only be 2.
So extending the length and limiting the band return along the bottom so that you still draw back to 5-6x active length should be the recipe- and the longer you extend the barrel the better it should get.
https://slingshotforum.com/topic/129528-size-matters-especially-length/?hl=%2Bsize+%2Bmatters
Hope you enjoy the forum, maximizing your machine, and just having fun with this sort of thing,
Discussion Starter · #16 ·
Now with added speed, the string wants to jump over or under the ammo sometimes. Is there a simple solution available for this problem? Can i weave the string somehow to prevent this to happen? At the moment string is only one time twisted loop. I really dont like to use "sled" for the ammo. It wastes energy and i think any Lego part wont hold this much accelerations. Grooves on the side of the barrel, where string moves, are tiny as possible can. What kind of string material is best for this kind of aplication? Now im using simple waxed fishing rope.
1 - 16 of 16 Posts
