1 - 7 of 7 Posts
Plant Fashion accessory Wood Tail Baby toys
Auto part Jewellery Font Fashion accessory Circle
Automotive lighting Gas Cable Wire Electrical wiring
Electrical wiring Cable Eyewear Wire Audio equipment
i have a new slingshot made today its really accurate
what do you guys think of the frame and way of attaching the tubes i know flatbands are better for this but i dont have them
Cable Wire Electrical wiring Fashion accessory Electrical supply
You can attach them straight to the fork without using anything extra at all and get just a bit more to stretch. Flatband showed me, and I like to attach mine like he does now. I like to use two grooves on each fork though for tubes.
thanks for the info i also use this method
but i wanted a new method to use
is the method on the newest slingshot a good one or is it less accurate than without the little bit of rope? View attachment 1678
Hmm, Did you shoot it yet? If yes then you should know if it is less accurate .
well actually it is really acurate but i wanted to know if there is a better way of attaching the bands with rope or use something else which could is be better
Leather is a good choice and looks better than rope. Cut a piece the same width as the fork, and long enough to leave about 1/4 inch between the hole for the band and the fork when passed over the top. Tie it on just like a flatband, though for this application, I think waxed string is more secure than rubber bands for the fork tie.
Henry
Henry
Thanks! thats a great idea im going to try it when i have the leather what do i need to use thick or medium like leather ?
1 - 7 of 7 Posts
