1 - 16 of 16 Posts
Well the Daisy is finished now. I have painted the fork and arm brace a matt grey colour, which is to replace the shiny "easily scratched" nickel plating which was on it earlier. All that it needs now are some good tubes, and then it is finished !!
I was thinking about maybe doing a camo grip for it though I think it may be going a little too far for a slingshot, It may be something I can do on another one instead. The p51 is not that bad a sling if you like tinkering around with things, as there is alot you can improve and/or modify on it.
Please give me some fedback,it would be most appreciated.
I have just bought another p51 (they were on sale
) so If this was a sucess, then I may start thinking of other things I can do to them to make them a little more unique, such as flat bands , grip modification etc.
There is a pic attched below, took it with my old low res digital camera, so sorry if they are a little...erm, messed up.....haha
Cheers,
AJ
I like it a lot!
Sigh... If only . . .
hehe, cheers Hrawk.
BTW sorry for the spelling mistake in my title, it is supposed to be PAINT job, not Panit job.....I couldn't find a way to edit it so I am not now panicking more than ever before (just kidding)
AJ
I have another P51 on the way (that I got cheap) that I will modify. I don't know just how yet. I will probably turn the fork tips forward and lower them a bit, then change the wrist brace angle and replace the arm rest to a more comfortable one. I still have two P51's modified with horizontal slotted tips welded on that I plan on modifying farther. Gary miller has one that I modified like with the slots. There are also 2 more out there with slotted tips, that I can’t remember who I traded them to. After being modified for flats they are a top notch shooter. -- Tex-Shooter
Reactions: studer1972
Tex,
Those slotted tips sure look great !!
I think I will modify the second p51 (which I am not going to paint) by making it suitable for flat bands also, but on an easier scale of the great work which you have been able to do on yours. Maybe by just bending the forks forward for starters.
Out of curiosity, has anyone on the forum modified the grip on a commercial slingshot (such as Barnett,Saunders,Marksman,Daisy slingshots) ?? It would be interesting if someone was able to create a nice,laminated wooden pistol grip for one of them.
That could be a future project...
Cheers,
AJ
I have another P51 on the way (that I got cheap) that I will modify. I don't know just how yet. I will probably turn the fork tips forward and lower them a bit, then change the wrist brace angle and replace the arm rest to a more comfortable one. I still have two P51's modified with horizontal slotted tips welded on that I plan on modifying farther. Gary miller has one that I modified like with the slots. There are also 2 more out there with slotted tips, that I can't remember who I traded them to. After being modified for flats they are a top notch shooter. -- Tex-Shooter
I got to try that with mine!
Warning, don't cold form a Daisy P51
I got the Daisy P51 in the mail today and went straight to the shop with it. I wanted to try to cold twist the tips to see if the chrome would flake. I did not see any chrome flaking, the rod twisted right off at about 90 degrees of twist. That jogged my memory a bit back to when I had slotted tips welded on 6 Daisy P51's. The welder had told me that he had to Heliarc the SAE 1016 tips on and that the slingshot steel did not act like any other that he had welded. I have cold twisted several Marksman 3061's with no problem. After I broke the tip off, I made a new one with a stick of stainless that I had. I don't know the stainless destination, but it was very hard to bend even when heated. I don't think the new extension will be bending even with heavy bands. I got a little extra extension with it also. In conclusion, the Daisy P51 is not an easy slingshot to modify! - Tex-Shooter
Cool Modifications Bud! I have one of your P-51 single slot modifications and it works great! Flatband
Has anyone had any probs with the flexi , plastic arm brace on the p51 ??
I have not found it too efficint, and it has been close to breakig under the strian of the bands.......so I have made my own more comfortable and strdy wrist brace out of some stronger material.
Will post a pic soon.
AJ
Looks great! All you need is a way to put flatbands
Cheers mate,
Well I have strongly considered using flat bands, though there simply aren't any in New Zealand gun stores,sport stores which are the only shops here that do supply slingshot rubber.
There is also a rubber store, though they only have very good quality tubes as oppose to flat bands which I am after.
Does anyone know where I could get some flat "rubber" maybe , which is as close to flat bands which I can get , as there are no specially made slingshot flat bands for sale here like thera gold etc.
AJ
The way the Daisy arm rest is made, it swivels to lay flat on your arm. You can make a longer leather one, but you probability will need to adjust the angle of the support rods so that it will lay flat on your arm. Something else that you can do is put a baby stocking (folded) over it to make it more comfortable. -- Tex-Shooter
Cheers Tex,
What happened was that the wrist brace snapped under the pressure of new "heavy pull" tubes which I have just bought form the local rubber shop. SOoooo, I made it a new wrist brace made from strong millitary canvas as well as pieces of other fabric and pleanty of duct tape.....then I finished it off by making it a stocking (due to not having any baby stockings around) and placed it on the custom made wrist brace I made it.
Now the wrist brace is much more sturdy, it fits my big wrist and the stocking makes it much more comfortable to hold when you pull the bands.
The p51 is fully modded now, though I am still after flat bands, I will keep an eye out.
Regards
AJ
1 - 16 of 16 Posts
