1 - 1 of 1 Posts
This is my review of my latest slingshot, which is designed and produced by Jim Harris at Performance Catapults. It is called the SPS.
I ordered mine in Cocobolo. I chose Cocobolo because of its beauty. I find the Dark wood, with defined grain pattern very pleasing to the eye. Well, my eye anyway. But, I also chose it for practical reasons. Cocobolo is a naturally oily wood. Thus, it can hold up well to water exposure and repeated use. That is why you find it so often used in gun grips and knife handles.
The SPS is a very versatile slingshot. The fork tips allows multiple band types:
  • Chinese Tube (Came with 1842 tubes)
  • RRT tubes
  • Flat bands
Lets look at each of my 5 Slingshot Review Points
Construction Features.
Multi-layer Lamination (I am unsure of Lamination Adhesive, but a visual inspection would suggest an epoxy of some sort.)
  • 1/4" Cocobolo wood
  • 1/16" black G10
  • 1/8" stainless steel core
  • 1/16" black G10
Lanyard hole with included paracord lanyard
3/16 Hollow stainless steel pins
Form Factor
The SPS seems to be designed to be used primarily as a finger braced slingshot, as it has Shoulder Supports for your finger and thumb. However, it can be used with other grip types. The small overall size makes for easy placement in your pocket, or in a belt holster. It has low profile forks, which should result in lower wrist strain and better accuracy.
The dimensions are:
  • 3.5" (w) x 5" (h) x ¾" (d) overall
  • Fork gap is 2"
  • Fork tips (concave) are 3/4" wide
Three different Grip methods
  • Hammer Grip, for those with smaller hands
  • Finger braced
  • Finger Wrapped, for those with larger hands.
Fit and Finish
The overall fit and finish to the SPS is very good. The laminate layers are even, so there are no edges to scrape your hands. It also has virtually no tooling marks on it at all. That is pretty hard to do on a multi material laminate.
Cocobolo wood has two colors, dark heartwood, and a pale yellow sapwood. This particular slingshot has a small amount of the sapwood visible on the fork tips. That does not bother me though, as I think it gives it character and makes it unique.
Those who know me know that I generally like high-polish finishes. This slingshot is an exception though, as it has a very attractive matte finish.
Quite a bit of attention was given to details on this slingshot. An example off is the alignment groove for Chinese tubes. It is right in the middle of the vertical part of the upper section of the fork tip(between the hole and top), and holds the tubes in the center of the tips. It also has counter sunk RRT tube attachment holes, which helps the tubes to stay locked in place when using the ball-bearing in-tube lock.
Safety & Durability
There are obviously quite a number of things done to make this a safe and durable slingshot. I like the fact that adhesive was not the sole method of ensuring long-term lamination. Adding the stainless steel pins were a nice touch. The combo of stainless steel and G10 core, reduce the chances of a catastrophic failure in the case of fork hit or some other damage. As mentioned before, Cocobolo wood has superior durability.
Versatility
Multiple attachments makes this a very versatile shooter.
For RRT tubes you can shoot through the fork or over the top. For Chinese tubes, you can use them over the top, or through the fork. The flat band attachment is strictly over the top.
I haven't been able to take any pictures of mine yet, but here is one very similar to mine:
Wood Font Landscape Metal Barware
Dog Dog breed Carnivore Liver Plant
THWACK!
Feb 09 2012 11:08 PM
Cocobolo! Yes! Other than an (unauthorized) pickax handle, my cocobolo was a great nightstick. (They call them "batons" now).
Loved that wood.
...and it's hard to beat Jim Harris for craftsmanship.
Very comprehensive review - many kudos.
Joint Hand Arm Shoulder Human body
Sofreto
May 15 2012 10:29 AM
Very nice slingshot and the post was very informative
Water Event Pattern Grass Soil
The Lard
May 22 2012 02:08 AM
I have a EPS and I'm extremely happy with it so much so that I'm also thinking of getting this very same SPS you've made a great choice
Sofreto
May 23 2012 02:00 PM
Beautiful piece of work and I enjoyed reading your post...Cheers, Sofreto
Hairstyle Eyebrow Eye Neck Jaw
ezshot
Nov 22 2012 09:27 AM
Aside from the beauty of the slingshot it looks to be a comfortable shooter too. My nightstick was also a cocobolo and it worked great for 20 years. I think they use Balsa wood now. Thank you for the post.
Tom
Musical instrument Water Music Event Art
jimmycg
Aug 15 2013 06:29 PM
The Cocobolo on this is very nice it is not always this beautiful.
Dog Carnivore Liver Art Snout
Susi
Jun 24 2014 06:40 PM
This is not only a work of art but looks to me like a very well performing semi ergo SS. The stainless steel core would add heft and some stability due to shear mass and the wood is dense, likewise adding to the mass and heft/feel.
Gesture Art Font Thumb Painting
Bulls-Eye
Sep 29 2014 02:11 PM
You just can't beat the natural beauty of wood!!!
Bulls-Eye
Sep 29 2014 02:17 PM
By the way all my night sticks have been made from ash.
THWACK!
Nov 05 2014 10:31 PM
I believe that I was supposed to use a Hickory nightstick - compared to Cocobola, that is like Balsa wood.
Would you believe that Balsa is actually a "hardwood"? Technically, yes it is.
1 - 1 of 1 Posts
