Here is my pouch design. I used pigskin from Tandy leather and Weldwood contact cement. I cut 1 inch strips 3 3/4 long and folded the ends back 1/2 inch and marked them. I glued 1 inch on each end with the contact cement and let it dry for 30 minutes. I fold the ends to my 1 inch mark and flatten. I used the handle of a screw driver to make sure I had good contact and a lot of pressure. I layout my pattern and cut with a pair of shears. I have a 3/16 oval punch that I use for the band holes and the band lock hole on the end.
The pouch that is on my slingshot has over 2000 1/2 inch steel balls shot from it and it still looks good. I am going to try and keep some kind of count to see how long it last's. The pouch weighs .75 gram or 11.5 grain. When you first start shooting a single layer of pigskin it feels paper thin. It will be interesting to see how long they last.
Looks like they ought to do the job.
I've just managed to acquire a very large quantity of pigskin leather - its only 0.7mm thick and as wingshooter said it feels paper thin! Incredibly strong though and should help with release technique as it is so thin! Good pouch design.
Thanks for this. Since leather makers learned how to split skins, the leather in clothing is so thin that it tears really easily. I will have to give this a try with some of that thin clothing leather to see if it holds up.
Cheers ...... Charles
Thanks for posting Roger. I like the idea.
I have been trying to figure out what glue would be best to use for a full length pouch lamination. It has to be something strong but flexible. Any ideas? Rubber cement? Contact cement? Gorilla glue?
Cheers,
Northerner
This weldwood contact cement seems to be working pretty good. I also think Barges leather glue would work. It has been around for a long time.The glue I got from Tandys let the edges lift up. Maybe I didn't let it cure enough. I am begining to think you don't need a full length lamination. This single layer pouch is holding up very good it does have a lamination at the band hole for strength. And it is very light. It will be interesting to see how long this stuff holds up.
Roger
See The Target
I like it. As Charles mentioned , it would enable me to use some of my thinner cuts.
Barge cement bar none is the fichizzle. It costs a little more, but less glue is required than others so it evens out, really. Excellent adhesion and pliability is retained. You simply will not find a better product for this purpose.
