1 - 9 of 9 Posts
Hey guys i got a bunch of these 2 home pouches for tubes with my last order as freebies and they're the 2 hole pouches designed for looped or double tubes and i don't really ruin alot of those set ups so i was wondering if it would be ok to just band them up for singles or flat bands or should i cut out the little pieces and connect the 2 holes? Any thoughts or advice would be greatly appreciated ????‍♂
Hey guys i got a bunch of these 2 home pouches for tubes with my last order as freebies and they're the 2 hole pouches designed for looped or double tubes and i don't really ruin alot of those set ups so i was wondering if it would be ok to just band them up for singles or flat bands or should i cut out the little pieces and connect the 2 holes? Any thoughts or advice would be greatly appreciated ‍♂
Pouches can be used with tubes or bands ... do have a picture of the pouch ?
Yes, that two hole pouch is for tubes it is not a flat or band type pouch. You could cut a slit in between the holes, but why bother when the correct pouch is cheap and you know it was made for your intended purpose.
1 - 9 of 9 Posts
