1 - 1 of 1 Posts
Been testing it, good stuff, different, but good, OK my draw is 32in. With theraband gold 6in active, taper, 1 1/8 in to 3/4 in, hold weight 12 lb, that's 500%,
With precise .7 red, same taper, with my device, at 30 inches was weighing 24 pounds and broke, snapped violently, 32 inches not possible, sooooo, with experimenting the precise .7 red stretches 400% very well shoots great, increased the length to 8inches, draw is 32 inches (400%) very good, holding weight is 15 pounds, get 210 fps at 30 degrees f., my theraband dropped from 244 fps to 210 at this temp, so if you cut it a little longer it's bout the same but holds the speed, GOOD STUFF, MY opinion only. Cold weather, should be fantastic.
1 - 1 of 1 Posts
