Hey Charles, was wondering how the tabs on these pieces are attached. Do you have both ends of the tabs connected on just one side of the fork or do you connect the tabs through the screw on both front and back of the fork. ( are the tabs together, or do they come up and over the top?) Hope I explained my question well enough....would you happen to have a side view of these slingshots? That would help a lot. Thanks much.I have been shooting "braided" Alliance 64s for the past week. My preference is for the braided method, rather than the chain technique that Nico uses. Here is the braid:
And here is the more usual chain:
The braid has several advantages, from my point of view. The braid does not require any tie at the pouch. You just pull the band through the hole and you are done. Further, with the braid there is no loss of length in the knots used for the usual chain; the rubber in the knots is wasted as far as supplying power is concerned. Also, the braid is self-adjusting; with the normal chain, it is easy to get the rubber on one side of the knot a little longer than on the other side of the knot. In addition, it is a LOT easier to replace a broken piece on the braid than in a chain. With the normal chain, when a piece breaks, it is about as easy to make a whole new band than to try to untie those knots without damaging the rubberbands.
It is very easy to make tapered sets, just by adding extra rubberbands toward the fork.
In my experience, using Gypsy tabs and braids, the set up is about as accurate as flat bands.
Whether you use the regular chains or the braids, you will increase the life of your bands if you dust them with a bit of talcum powder ... baby powder works well. Put the rubberbands in a baggie with a bit of talcum, and shake it up well. Then take the rubberbands out and shake off the excess. Then proceed to make your chains or braids. The talc helps lubricate the bands and cuts down on wear.
Theraband gold will be faster with a lighter draw. But for availability and cheapness, it is really hard to beat office rubberbands.
Cheers ........ Charles
