the proto type seems ready to become a design all the snags seem to be sorted out
The new photo shows the design I will be making this is just a rough tester in steel showing were the handle will be cut out I may thin the handle a little more but not to much I want to be able to adjust it as he grows so it will last him a wile it will be made of thick brass or thin brass and wood laminate and I will spend a lot more time on it to make it look nice it is designed so this kid can use it with ease and his buddys will be able to shoot it I also got the inspiration for my Grim Reaper whilst working on this design design
I also removed some photos of a couple of mistakes I made and put them back in way down the page
Hi this is a simple design I came up with and is a proto type I am working on I will explain why later if your just here to have a quick look and want to have ago at one its made from 20mm x 5mm flat bar bent into this shape drill a couple of holes and throw your bands on simple enough and you only have to look at the first 2 photos. If your still here the reason I designed it this way it is a proto type it will be for a kid with no fingers just a thumb on one hand now its a prototype because its got to be properly tested out so if it doesnt work out sadly he won't get one, but he could still have some sort of sling x-bow so all will not be lost, he will have fun anyway. I have looked into some sort of release aid but if he holds the slingshot in his good hand it would be next to impossible for him to load it. This is just a realy rough version and has been bent to fit my hand I will be bending up a few to get it right then it will be padded with leather I can grip this puting my hand through the centre of the handle and curling my palm with my fingers straight and not wrapped around the handle with a bit of modification i will be able to grip it fairly securley with my thumb it will have a lanyard, his will have light weight bands and hopefully look pretty cool. I think its quite interesting design as it is it can be griped inside or outside of the handle
THANKS GUYS heres a quick update I welded a thumb tab on this realy helps with the suport and used a make shift lanyard and this realy makes this stable, couple of new photos on if anyone would like to have a look and I'am looking at making a multiplex model so thanks for your ideas keep them coming, I'am hoping to make this look a lot cooler and use diffrent materials
All that effort and a simple black widow, lanyard and a leather strap works nearly as well why did I not think of that first? lol at least Ive got a head start when he out grows it so I will be carrying on with the idea but at least he will have his slingshot Thanks guys if your intrested in the tests and how its working out you will have to scroll the page now as I will put some more info and photos on
