1 - 19 of 19 Posts
Hi guys,
I have a method that is working ok to groove the wooden forks, a wood carving groove tool then sand paper around a thick flat metal handled tool for the roughing part of the catty but what method of making the grooves are you using? There must be an easier way.
Thanks in advance.
Ray
3/8 inch round wood file. Tex
I use a dremel too. Flatband
Actually I use a router on 3 sides and a 3/8 diameter inch file on the forth. However I figgered that some one would want somthing cheap and I have used the file on all four sides. It is fine if you are making one or two at a time. Tex
Dremel with 3 cutting wheels together.... or Dremel router attachment
I do my Dremel tool by hand with a round (1/8") diameter Structered Cardbide bit.Make a pencil mark around the post,and then just follow it around with the tool at medium speed. Flatband
i use my table saw set really low for board cuts then use a chainsaw file to round it out and cut out the sides, for tree forks I have used the chainsaw file all the way around before and I have also done a plunge notch on just one side like rufus hussey both ways hold just as well, the chainsaw file notch looks a little more professional though.
Dremel with carbide burr, followed by 3/16" chain saw file for touch up. Pencil line to start, free follow line with dremel.
1 - 19 of 19 Posts
