1 - 9 of 9 Posts
I have been lurking around this site and asking a few question and have recieved great responses. Thank you. I am going to ramble a bit here about my thoughts. I do not know enough at this point to get them organized. My ultimate goal is to hunt hogs. I have extensive trad archery experience. I have been following threads on tubes and flat bands and this has raised some more questions. I want a setup that will shoot an arrow wt of 500 gr. This is significantly hearier that typical SS ammo. I feel that I need to be shooting that arrow somewhere faster than 150fps. I intend to use a draw lenght of about 30 in. What factors influence the power in a SS? how do shorter bands change things? I assume longer bands can have more power but only if you draw them farther. I assume that as soon as a band reaches its resting length it is done working. I also assume there if a draw length of demonished returns or failure for a band. It seems logical to me that the longer the bands are appling force to the ammo the more force will be transfered to the ammo. I have no idea what a heavy SS draws but I draw 65#@28" on my longbow comfortably. I assume SS draw is limited by pinch strength more than draw strength. How would ya'll the experts set up a rig to do what I want? Please feel free to answer anyor all my questions and correct me where I might be thinking astray.
I have worn out Chiefs site. That is wear I got the bug to do this. THe penetration worries me some so I am looking for a heavier set up. His set up uses black tubes. Are they the heaviest? What about double bands?
Pro-Staffer, Glenn Trame came up with double tubes. Glenn uses a release to shoot this. Here is how to set up using a release on slingshot. The Black tubes with 1/2" cut off have shot into a Feral Hog 11" by Chris Stanley and Chris did it on Video and is being shown now on the Sportsman's Ch. This the new age of Power shooting, shooting 210# Gator Gars, 200# Hogs, 160# deer, it is being done with slingshots NOW, not dime store slingshots but with the all solid Metal HFX. The Chief
I'm no expert on arrows shooting. ChiefAJ's friend is and he started with a proven bow hunting rig and made some mods to improve on it, by doubling the bands. Of course, he could just as simply have used a heavier band, but the idea of starting with a good design is sound.
BTW, to clarify, I use 'bands' interchangeably with 'tubes' above. You will have read a lot of debate about flat bands versus tubes. The more surface area per volume a band has, the more power you will get out for the power you put in and the faster it will contract under light load, within practical limits. A thin walled tube is as good as a flatband. If you're not stretching for high velocities and your shot is heavy, I feel a tube is a practical choice. I haven't experimented with tubes versus flatbands for heavy draws and that comment is purely intuitive. I like the idea of the tubes' reliability. Thin bands tend to tear. If a band goes on an arrow rig, you may snap the shaft, and that sounds scary.
I have worked on the arrow shooting slingshot concept for a while, and found that the limiting factor pretty much is the draw length.
A bow (or crossbow) has pretension, which does not work for a slingshot. So you must compensate. I solved that limit by using a whisker biscuit attachment that is behind the fork, so the arrow can be shorter than your draw.
I also designed a pouch that works better than the releases I tested, plus it can still shoot normal arrows.
Here:
As for the 500gr weight, I shoot balls that are much heavier than that, and 150 fps is well within reach for a trained athlete.
here is something that might work with a little mods done this is just my prototype of a 16 inch starship with no wrist brace Its a little rough still need work but is easy to handle and accurate with a arrow rest you'd be set.The pictures are a little rough but you should get the idea.
Joerg, I would not want to arm wrestle you or get into a bench press competition with you but I can hold my own fairly well as a trained athlete.
ZPD, May thoughts about a wisker biscuit are the same. A rig like Chiefs works like a drop away rest. BTW, I would not want to arm wrestle Chief either.
Picked up a Black Widow the other day but I have not been able to shoot much YET! It has some really narrow forks. Not sure if I like that or not but hey it was only $10. I will work on form and tech.before progressing to heavier bands and arrows.
Thank you for the input.
1 - 9 of 9 Posts
