Safety matches have a chemical in the match head, that needs to be connected with one in the striking strip, I don't think you could do it like this. Swan vestas though, they can be struck with friction, and originally it was phospherous (I believe) coated with wax; rub the wax off, start the reaction.
· Philly
When I first saw the post I thought it was about actually using match sticks as ammo. When I was a kid, long ago we use to take an empty wooden sewing thread spool and tape a rubber band to it and shoot strike on anything matches through the spool hole. Actually worked.
· Philly
Bringing back memories, how about linoleam guns, same thing with the spring close pin release to launch a small piece of flooring material that was laid between the rubber bands attached to a wood pistol frame. Never knew where the tile was going as it was flat and really caught the wind.
Im still waiting for the POLO, you could start with a tyre then work you way down to a douhnut then a Polo, ha ha , jeff
Gonna need alot of patience and a lorry load of polo's I think,I have some slingshots to finish and a car to sell hopefully give it a go this week,I have stuck the polo's to a peice of cardboard without thinking, the carboard is white
but I have a solution to this problem I will colour the holes in with a black marker pen.
Winning the lottery is about 14million to one I have more chance of hitting that than doing this but then again never say never.
